Y-Guy
Jun 06, 2018Moderator
I can't say about that specific unit, but others have had this issue with different toys. Measuring the Teryx and figuring out the peak where the roof of the Teryx is likely to be at the highest point on the ramp is the # you need to know. Plus plan if you ever put on some larger tires.
I do recall one member had to disconnect the roof of his golf cart when loading. Another member removed the cabinets that abutted the loft to accommodate his setup.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
