Durb
Jun 25, 2017Explorer
oldbird1965 wrote:
Not to start a war but the extra capacity pan's don't do any good. Your best bet is the largest cooler you can stuff in there! What trans oil temps are you running pulling the 5er?
They do a lot of good if you adhere to a splash and fill maintenance regimen. The drain plug transforms a messy time consuming job into a clean easy procedure. My transmission fluid runs 160-190 normally and will jump to 220 on a long grade in the summer pulling 10k pounds. Fluid looks perfect all the time.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
