Two things first: (1) you need to write in paragraphs, your post is very tedious and nearly impossible to read. (2) You need to make this a New Post, no one will see it here; it is vastly overwhelmed by a 10 year old post that no one cares about.
Now to your problem, You need to check out the 12 volt side of the RV. Are any fuses blown (not breakers those are 120V, the 12V fuses)? Does the converter work? Do you have a 12V battery installed, is it connected properly, is it fully charged? Your problem seems to be the 12V system
You should have check the latest response to the OP's question dated Nov-19-2013 where he provided the answer to his problem.
- bid_timeMar 24, 2024Navigator
Actually my post was directed to KevinKessler at the end of this post. But somehow it didn’t come out that way. Chalk it up to being a beginner on the new format of this site.
