otrfun wrote:
Thinking about upgrading from 80 PSI E-rated tires to 110 PSI G-rated tires.
I assume 110 PSI air is available at most Love, Pilot-type truck stops?
Anybody use a portable air compressor? If so, what make/model?
Finding stations that have the 110psi could be difficult. I have my own compressor(Sears) with a capacity to fill to 110psi. Another alternative is to go to a tire shop. I use Les Schwab in Ca. Or. Wa. but I don't believe Ariz. has Les Schwab. Once I air up my trailer tires to 110psi at home I generally don't have to worry about loosing more than +/- 1 lb. of air. after being on the road for 3 to 4 months. I also use metal valve stems which prevents air loss.
