Devocamper wrote:
I carry a small CO2 tank with regulator and hose takes less room than a compressor that takes forever to get to the higher PSI's and I am able to get the 110 psi with no problem, only use it on the road if I need to adjust tire pressure . I made my own set up but take a look at Power Tank brand you will get the idea. Off road guys use these tanks to air their tires back up after rock climbing or running off road
m
I've had a Power Tank for several years. Very happy with it.
I have the 15# model. In retrospect the 10# would have been more than adequate.
