You have got enough posts for you to know that it is not a good idea. There are not many fivers that should be towed with a 1/2 ton truck. Forest River stated that my fiver, 2012 V-Cross 275, 32 feet long, loaded up ready to go, pin weight 2,000 lbs and trailer rated for 9,950 lbs can be towed with a 1/2 ton. I would not even think of pulling it with anything less that what I have, 2011 F250, diesel, CC, RWD, longbed. Additionall, the tires on the type of fiver you are looking at are rated for 65 MPH and should not be driven at higher speeds.
