lincster
Jul 23, 2016Explorer
drmopar wrote:
There is a difference in 4 wheel and 6 wheel Brake Controllers. You may not have full voltage with your stock controller. You can check with voltmeter at trailer female plug on TV. As stated above, brake adjustment is also important, but you should never lock the trailer brakes on hard braking. Wiring is also important, but make sure your start with the right Brake Controller.
The OP has a F450. I can guarantee the controller is rated for a 6 wheel trailer. That truck was built to tow.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
