I'm looking to upgrade my tires from E to a G rated tire. I can not find a psi rating on the wheels,but they are stamped 3960lbs. This would tell me I should be able to put a g rated tire on them. Any...
I found mine on a label on the inside of the rim when I had the tires replaced in Sept. Mine are steel white painted and are 110psi rated. These are on an axle with a 5080# rating, 8 lugs, 16" LE factory tires. The 5er has a gvw of 12,100. Go figure.
