I'm looking to upgrade my tires from E to a G rated tire. I can not find a psi rating on the wheels,but they are stamped 3960lbs. This would tell me I should be able to put a g rated tire on them. Any...
I just had to replace rims on my 2010 Montana. So the answer to the questions are fresh in my mind. The G614 tires are rated for 3750 lbs. and the rims are rated for 3960 lbs. Therefore a slight rim advantage. One of my rims was porous and had a slow leak. Upon closer inspection the rim had cracked spoke. We think the rim probably cracked when the axles bent. They have never visited curbs but fairly familiar with potholes. Rving is fun owning an RV quite debatable.
