Sgmiller3 wrote:
My partner and I just bought a 1976 Terry with the intent to gut and remodel, and we're first needing to put new tires on it. I've scoured the Internet and can't find what size tires to put on it? I would just look at the tires on it already but it is currently on cinder blocks. Can anyone help me please?
Much appreciated,
S.
Size (length) of trlr?
I had a 24' 1976 Terry (TT) back when.
A guess would be - a 5th wheel probably had the same tires as TTs.
It had 15" wheels - I used LT tires (even back then).
Since you're in a re-hab mode, would guess any tires would made do for the time being - find some used 15" LT tires.
Want new? Lots of "current" 5th wheels have 15" tires & wheels. Take a look at a sidewall on a comparable size trlr on a sales lot.
On cinder blocks......
If you need wheels also, the 15" wheels used then were a standard Ford p/up bolt pattern.
Make (and take) a cardboard pattern to the local wrecking yard for inexpensive wheels.
Good luck with your project.
