n7bsn
Sep 09, 2014Explorer
mobilefleet wrote:
instead of chasing down a nightmare why don't you just tap into the hood light and run a wire to the fan switch and be done with it. Use a scotchlock connector to tap into the light's hot wire. They are both 12 volt
On every rig we've owned that had a powered hood, the power the feed the fan also fed the light, same lead from the 12v power block.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
