Radonguy's avatar
Radonguy
1996 Nash Fifth Wheel
I have a 1996 Nash Fifth Wheel I just bought. It has two 1/2" tubes coming out close to the rear bumper that have started to leak when the pump is turned on. I think they may be low point drains but not for sure. Any help would be greatly appreciated.
  • CA Traveler wrote:
    Low point drains will have valves inside. Check under cabinet floors etc. They should also leak with city water. Hope this helps.
    not always, some just have a cap that screws on the end of the drain pipe.
  • I had a 2004 Arctic Fox 24-5N....same as the Nash. Low point drains at rear of trailer. Valves were accessed by removing the bottom drawer in galley and valves were at the rear of the cabinet base. Hope this works for you.
  • Sounds like low point drains. As stated look inside under cabinets and such. Once you find the valves figure out how to turn them off. Might be a twist or might be a push down to turn off.
  • Welcome to the forum!
    ^Above advice is likely correct. If no visible shutoffs on outside, then look directly above inside.
    Jerry
  • Low point drains will have valves inside. Check under cabinet floors etc. They should also leak with city water. Hope this helps.
