jimmyfred wrote:
............Pull the plastic cover off the A\C , take a bright flashlight and inspect the area where the cold air is SUPPOSED to be separated from the return air ! There should be a tin metal partition that separates these two items and it should touch the metal surface of the unit on it's upper edge . ANY , gaps , will allow the emerging cold air , to be sucked back into the return air thus reducing the volume of cold air available to cool your camper . These units are designed just like female anatomy , the INput and OUTput are real close together ! , lol , jf
LOL yes. Did you mean pull the cover off from on top or from inside?
