FastEagle
Jul 18, 2014Explorer
1Adam12 wrote:
Not if but when! We have been towing various configurations of travel trailers and fifth wheels for a long time coupled with different trucks and large SUV's. We have had one blow out in that time until Sunday. Coming home from North Georgia we lost the first passenger side tire on the 5ER outside of Macon. A short time later the second tire blew on the same side just north of Valdosta. Now it's late and we don't have a second spare. Luckily we were near and exit during both incidents and able to pull safely off the road. Sunday morning we started the fun of finding a tire on Sunday morning. Two things I learned from previous incident were number 1 have an RV tow service coverage, we use AAA but any will I'm sure work. #2, you can be prepared as best as you can (tires checked and at 80 psi) and less than two years old and it can/will happen. The TV is a 2013 Ram 3500 dually with zero damage to tires. The RV is a covered stored 2013 Keystone Montana 3750. The tires are Goodyear Marathon ST 235/80 R 16 E . We have taken this coach to north GA twice and SC once as well as multiple trips around FL. There is extensive damage to the wheel well area, landing gear and under carriage from the tire(s) exploding. I'm not brand bashing or complaining about anything but I guess I will look at load range E or F tires to get that confidence back. By the way my top speed is 65. Sheesh. :S
I’m pretty sure your 15770# trailer has 7000# axles derated to 6750#. With the LRE tires your replacement prospects are very limited. ST235/80R16E and ST235/85R16E are probably the only LRE 16” tires that will meet your axle requirements. Did you look in the owner’s manual to see if Keystone offered the optional LT235/85R16G ? If so your rims may support that tire fitment.
FastEagle
About Fifth Wheel Group
19,039 PostsLatest Activity: Jan 28, 2022
