billy1davis wrote:
So I have 2001 Dodge 5.9 Diesel Dually 3.55 gears auto 4 speed and the towing charts indicate that total trailer weight capacity is near
10,000lbs. Is this too conservative?? Can I go up at all? I know the truck was one of the heaviest duty truck at the time and they were making many 5vrs weighing more ??
Here are the towing charts for the 2001 Ram CTD, well you don't state if Regular cab or Quad Cab, 4X4 or 4X2.
Depending on those factors, max trailer is as low as 9,050# or as high as 9,900#.
So the side note is I have a 2001 2500 4X4, 5 speed manual, 3.55's, Quad Cab long bed. It is rated to tow 9,300#. Our current 5er is 12,360# GVWR and have not weighed since starting full time, but believe it is about 11,600# currently.
The real issue you need to make a decision about is running over the Rams GVWR. That is your choice. The GVWR on the 2500 is 8,800# even with optional 265/75-16E tires (3,415# capacity), camper and tow packages, currently over that by a ways.
The max GVWR in 2001 is 11,000# for the 3500 Quad cab!
These are the charts out of the owners manual.
