S_Sullivan
May 22, 2013Explorer
Much thanks to all of you for your responses. We have already decided that any used unit we purchase, we will have an independent RV inspector go through. I will mention the Lippert frame issue to him.
So - my question is this. Should we be concerned about having a pin weight over 2000 lbs on the truck I have listed below:
2003 GMC 2500HD / Duramax / Allison Trans
3.73 gear ratio
4WD
extended cab (NOT crew cab).
Weights as follows: full tank of fuel with DH and I:
front axle was 4180
rear axle was 2960.
Is a Husky 16K manual slider hitch okay for this unit?
Again - THANKS!
3.73 gear ratio
4WD
front axle was 4180
rear axle was 2960.
Again - THANKS!
About Fifth Wheel Group
