Word of caution the side walls are sagging slightly. Look at the wheel well on the left side under the sofa and see how it is angled. Hard to tell on the right side but it may be tilted as well. WHen the trailer was new those wheel wells would have been square to the wall. This was a common problem with several manufacturers around that time due to weak outriggers welded to the outside of the frame that hold the walls up. I had this same problem on my 2004 WW FK19 Superlite. FWIW I sold that trailer last year for $4,200 and it also had a soft spot in the floor from water damage.
