nayther
Jul 02, 2020Explorer
Clearcreekduncan wrote:
Falcon 30-05 & yes it has an onboard generator. We know about the plug, but that doesn’t seem to be where the problem is. It all worked last week. Now we have no power for air conditioning or power for the microwave, or anything that runs with 110 power.
That's exactly the same trailer we had (sold it to wife's godson, he loves it). I knew that thing inside and out. You need a voltmeter first and foremost. Like Dave said, check generator breaker first. Then check voltage at the plug at the shore power cord. You should see 120 volts from hot to any grounded surface or to ground or common. From there go to fuse panel and remove the cover (four screws in the corners), do you have 120 volts there? Also check the actual shore power cord and plug, I've had conductors pull out of the plug before, that cord gets pulled in and out of that little compartment a lot and is susceptible to damage. I ended up cutting mine way down and making the cut off part into an extension cord. With about 10' still attached to the camper I could reach most pedestals without using/pulling out the big cord
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 15, 2026
