valhalla360
Apr 30, 2015Navigator
Check the pin weight and other ratings to make sure you are OK with the fully loaded trailer but otherwise, it's perfectly fine to run at the full ratings.
Yes, a diesel version will beat you in a drag race but unless you plan on drag racing, you are fine. You can tow right up to the limits and it's fine.
Climbing grades, you will drop down a gear or two and the engine will run at a higher RPM but as long as the truck is in proper running condition, this is nothing to be concerned about.
About Fifth Wheel Group
