MFL
Mar 27, 2017Nomad II
I have noticed if the tanks sit dry over Winter non use, the valve seals tend to dry out, making the levers hard to pull. I make sure to add a good non ethanol anti-freeze to the tanks, especially the black. In Springs first use, the levers pull easily, like lubricated. FWIW, I use Prestone RV anit-freeze.
You can also purchase valve seal lube to put in the tank.
Jerry
Jerry
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
