Yes, a dry weight of 10900, but do you plan to tow it with nothing in it?? Gross is just over 14K so real world Pin could be upwards of 2800 Lbs so you need to look closely at your numbers.
And to JrWhited: That's a first about AirBags transferring weight back to the Front axle. If the fifth wheel is set up properly (at least with a long bed) there should be no extra weight on the front axle, it's all carried on the rear axle. We carry 4K of pin and it's all on the rear duals, front axle is the same fifth wheel or not.
