mrkoje
Jun 28, 2016Explorer
bertmary wrote:
I have a 2011 Cedar Creek RE 5th wheel. I am having low voltage battery issues. I cannot run my battery operated ceiling lights. My automatic leveling system shows low voltage/error message. I have a residential refrigerator. The freezer works. The refrigerator light is on but will not cool less than 40 degrees. I occasionally have to plug up to my truck to make sure the batteries are charged. The battery compartment says 4-6 batteries; no less than four. I have four. Any solutions?
A couple of the things here stand out. 1st thing is you have a residential fridge which means that if you're not hooked up to shore power then the fridge is running on batteries which in turn then means that it's running off an inverter.
Depending on how large your battery bank is it won't take long to blow through those batteries especially in warmer weather or when the inside of the coach is warm. http://www.gonewiththewynns.com/rv-residential-refrigerator-power
Second thing is that you state the shore power will not charge your batteries. This is not typical as the shore power "powers" the converter that should be installed in your coach. The converter takes the AC and converts it to DC and then into the battery bank. https://www.batterystuff.com/kb/articles/battery-articles/battery-basics.html Two things to check here - 1st you might consider getting your batteries load tested. If they cannot sustain a charge up to 13-14v then you might want to replace them. This really might be the case if the batteries have been allowed to drain lower then 50% repeatedly. 2nd - you may consider replacing your current converter with a smart converter such as one from Intellipower. http://www.progressivedyn.com/about_power_converters.html
Let us know what you find out - I'm curious as to what the issue is. I love the space of a residential fridge but my wife and I found out that it wouldn't make any sense for the type of camping/traveling that we do and the battery power requirements that would be necessary for it to work properly.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
