brokeagainbutno
Aug 07, 2015Explorer
I am posting a little late, found this thread because I follow Jerry's comments. Before his 5th W, he had a MH like mine so he has seen the problems:)
In regards to the converter, a good maintenance check is the ground. I was having problems with my AC kicking in and out, the converter going off-line, etc. Only by accident, not any diagnostic skill, did I find a ground problem. I burnt my fingers where the ground was attached to the frame. It was in the open where road crud could hit it. I cleaned it up, etc ... solved the converter and AC problem. It would be a good idea to periodically check the ground, especially if it is exposed to the elements. Maybe this will help someone researching converter or AC problems
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
