joebedfordNomad IIIDec 13, 20132011 Voltage 3950 pin box replacementI'm seriously considering replacing the fixed pinbox on my rig with a Trailair tri-glide. I don't know what the pinbox model number is and more importantly what the equivalent Trailair model is. The m...Show More
Sprinks542ExplorerDec 13, 2013If you have a plastic cover on it pull it off and check on top of the pin box itself. That's where I found mine at.
Related ContentVoltage Dump Valve Replacement2011 Dutchmen Voltage 3905Water Heater Replacement RecommendationsLow Battery VoltageReplace insulation inside heater column.
