Peg_Leg
Aug 20, 2013Explorer
You say 6100 on the rear. This means you've got E rated tires at 3042 lbs at 80 psi. This is your weak spot. You might be able to find some 3400 lb capacity tires to help out. This would not change your rear axle rating or your GVWR, you would have to get a DOT inspection and recertify the truck for that. But your not a commercial vehicle either.
The rear is also sprung for 6100 lbs so you may be looking at some more upgrades.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
