sdetweil
Aug 21, 2013Explorer
losmt21 wrote:
So everyone, I should be okay towing the 2014 gateway fifthwheel.
I was told the dry weight is 11,000 and someone also said just add 1000lbs to then dry weight and it will be total 12,000
For the fifthwheel. I will be upgrading the springs and adding airbags to my truck. As much I will be towing this camper 15 minutes away from my house . Maybe a trip out of ga once every couple of Years.
based on what you've told us, I think with careful attention to the hitch weight load, you will be ok. you might want to consider packing some supplies in the back end of the trailer to reduce the hitch weight, don't travel with water, etc.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
