losmt21
Aug 22, 2013Explorer
PA12DRVR wrote:
BlindGuy,.....I guess I'm a bit unclear about the thrust of your post. Won't argue with the facts/info as presented, but it seems to me that you're suggesting that the OP (or others similarly situated) should look at the sticker to determine the load capacity of their rear or front axles.
I certainly don't disagree with that.....but one of the issues that routinely pops up on these forums is "GVWR" and "GCVWR"....if one is to follow/rely on the door sticker's ratings for front and rear axle weight ratings, shouldn't one also rely on the GVWR and GCVWR as posted on the sticker (if such ratings are on the sticker)?
All moot of course since the OP, as is his right, has decided to go on the "I'll do what the other guy is doing" route.
Correction: My mistake, The dry weight was #12,800 with a gvwr of over 15,000lbs.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
