AH64ID
Mar 21, 2014Explorer
If you do mostly interstate then either is fine, but if you find yourself in slow speed stuff frequently the 4.10's will shine.
Personally with the double OD's of either the Aisin or 68RFE there isn't a good reason to not get the 4.10's.
Moving your 20K+ lbs down the road is going to take the same amount of power regardless of gearing, but the lower gearing will reduce the stress in the motor/trans and spread it out to the diff as well.
I would also try to find a truck with the Aisin over the 68RFE.
If I where to buy a '13 or '14 DRW it would be the Aisin/4.10 combo and nothing else.. my current trailer only weighs 8,500.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
