Shadow_Grey
Jul 20, 2014Explorer
rhagfo wrote:Golden_HVAC wrote:
Hi,
Yes you will need to have some concerns with a 1/2 ton towing a fifth wheel. Most 3/4 ton's have problems with exceeding the GVWR while towing a fifth wheel too. Yet it is possible. No you do not require towing a 25' trailer, you should be able to find a 30' or 32' with a light pin weight. Not a Montana, or Grand Teton. But some of the lightweight, and other trailers should be fine.
If it is a shortbed, then Superglide hitch is another requirement to make it work right, without the front of the trailer trying to come inside the back window.
A extended pin box can also lessen the hitch weight a little bit. That just makes the distance between the front of the axles and the pin box a little farther, and thus less weight on the hitch.
Fred.
Really the commissioner of the Weight Police is encouraging using using a F150 to tow a 30' to 32' fiver ! While there maybe a couple out there that will fit in the payload capacity of a Max/Max it is still a light duty pickup truck! The GVWR of this rig is very close to the total of the axle ratings, making it easy to exceeds the rear axle rating on a semi floating rear axle (single bearing riding on axle that also supports the load).
While I tow over my GVWR I am well within my axle ratings, and don't need air bags or Timber's to support the load. This is not the Pot and Kettle, it is an 2001 TV with a one size fits all VIN sticker.
I am not saying that a F150 can't tow a correctly sized fiver, BUT it has to be correctly sized should not NEED bags to support the load.
Yep, with over 10,000 miles of towing my combo, I am still waiting to have that little semi-floating rear axle fail and the wheel go flying out from under the truck.
Set your combo up right, know your limitations, setback and enjoy the scenery...Happy camping to all.
About Fifth Wheel Group
19,036 PostsLatest Activity: Apr 08, 2026
