laknox
Oct 14, 2013Nomad
wandering1 wrote:
I had the same problem. I have a rear holding tank as well as a front holding tank. The cutoff valve for the rear tank is close to where the tank is located with the PVC running half the length of the trailer to the point where the sewer hose connects in front of the axles . When I empty the tanks, water accumulates in the PVC between the rear cutoff valve and where the hose connects at the front. The next time I remove the cap to connect the hose the water that was left in the PVC runs out. To drain all the water including the residual in the PVC from the rear tank I lower the landing jack legs so the water will run out of the PVC. Poor design but not the dealer or manufacturers problem once you own the trailer.
I'd dispute that, especially for a trailer under warranty. If the design shows that there's supposed to be a certain slope from the tank to the drain but the =build= doesn't meet that, then you bet, it's the manufacturer's fault and the authorized dealer's duty to fix under warranty. I do understand that not all dump sites are perfectly level, but you should =not= be having water left in your dump lines due to a "rise" (or dip) in the pipe. If there is one, it's just indicative of the generally mediocre build quality in the RV industry.
Lyle
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
