rhagfo
Dec 16, 2014Explorer III
Well you are going to be over your GVWR, so I can only tell you what I do, but can't recommend it as that is your choice.
We tow a 2005 Keystone Copper Canyon 293 FWSLS with our 2001 Ram 2500.
5er
Dry 9,860#
GVWR 12,360#
Wet 11,000# (weight I tow at most of the time).
Ram 2500
GAWR Front 5,200#
GAWR Rear 6,084#
GVWR 8,800#
Last couple times we have hit the scales truck scales at 10,000#, 5er about 9,100# on the axles total GCVW 19,100#+
I worry less about GVWR than axle and tire ratings!!!!
I have 600#+ to spare on each axle. My 265/75-16E tires carry a 3,415# rating each. So I have 1,284# to spare of axle capacity and 3,660# of tire capacity.
I do a lot of towing into the Oregon Coast Range, I don't hold up traffic can pull at speed, and feel 100% safe driving the narrow two lane state highways to the coast. this with a 5.9 with 277,000 miles and less than 285HP.
The choice is yours, keep in mind if you have 17" tires, the 265/70-17E only have a 3,195# capacity each.
That and you will be over your GVWR.
That is this rig, without bags or Timbirn's
Running on roads like this at 55 to 60 mph.
5er
Dry 9,860#
GVWR 12,360#
Ram 2500
GAWR Front 5,200#
GAWR Rear 6,084#
GVWR 8,800#
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
