stro1965 wrote:
I have, as of this week, a 2014 Ram 3500 crew cab 4x4 with the 6'4" box too. Already have my 5th wheel hitch installed, and it is 4" closer to the cab than it was in my F250 with a 6'6" box. I had to be very careful with the Ford, it would have made contact if I weren't. I'm buying a slider tomorrow.
I too came from a ford shorbed 350, yes my new Ram the hitch is four inches closer to the cab then the ford, never a big issue with the ford ,normal driving nothing to worry about, did get close a couple times backing up, but then I have a slider if needed, but never used it other then backing into my rv pad beside the house which is pretty tight. Using the same slider on the new truck. Have towed once with the Ram, everything looks okay. If I find myself needing the slider for normal backing or turning around very often I will go with the ISR series superglide. IMO the manual slider is a PITA, if having to use often.
