stro1965 wrote:
I have a '14 Ram 3500 and I'm trying to work out a solution to my "nose high" problem with a machine shop that does a lot of work for my RV dealer. He is concerned that mine needs to go up too high and that spacer blocks are a bad idea. He is contacting KZ for their input.
Somewhat the same issue, I may go with just two inches with spacer blocks, certainly would not go any higher
Other solution is cutting off the hangers, welding new hangers to a heavy wall tube, whatever you need to raise the fifth wheel , and weld the tube to the frame, then going with the braces ,such as the MorRyde X-Factor. This seems the better way.
