NC_Hauler
Feb 07, 2014Explorer
Gunship Guy wrote:
I ordered our '13 with the factory hitch package. The dealer threw in the picture frame adapter for free. It's still in the box. I have no intention of ever using it.
I installed the Andersen Ultimate 5th wheel hitch. I can describe this hitch with one word. Amazing.
I was skeptical at first since it's unlike any 5th wheel hitch on the market. I did extensive research and spoke with Andersen reps. After towing with it, I will never go back to a conventional 5th wheel hitch. It's just that good.
No jerking or chucking. Extremely easy to remove from truck when full use of the bed is required. Installs in under 2 minutes (yes, I timed myself).
Specifics I like:
-Simple
Keep telling people this, glad you tossed that out there. First one I heard of was over on the cummins forum back in May or so...guy from TX towing fairly heavy.....since then, quite a few have went that route, and again, I came really close, and eventually may go that route. Teh hitch only weighs about 40# or so, if not mistaken...
heck, if you're going to can the picture frame adapter, odds are you could make a little money off it..there are still people in process of trying to buy one.
-Extremely strong
-Uses trailer's factory hitch/king pin
-King pin block is easily removed so trailer can be towed with conventional hitch (if you take your 5'er to a dealership for service, etc)
-Inexpensive
-Truck bed space loss is minimal. Small items can fit under the hitch, if necessary.
-I have more than enough space between bed rails and trailer nose. Need to measure, but it looks like about 8".
-No grease/lubrication is needed because there are no moving parts. Hitch stays dry and clean.
I certainly understand the confusion and skepticism out there over this hitch. It's something people aren't use to seeing. But that's the way it is with everything new and different.
About Fifth Wheel Group
