kakampers
Oct 04, 2014Explorer
You did not say if it has dual pane windows....if it does you will not have condensation. Staying in OH I would skirt it, add some auxiliary heat inside...we used fireplace and an electric oil filled radiator. We also put batten insulation in the UDC to protect the water connection as heat from the belly does not reach. We had no issues and our furnace cycled normally it did not run constantly...and we did not skirt ours. We did use a heated hose and insulated the park's water bib.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
