Roger10378
Sep 15, 2020Explorer II
Look at the sticker on the drivers side door of your truck. It will give you the weights for your truck not the averages. Now for the trailer you can normally figure around 22% of GVWR for pin weight that gives you a fully loaded pin weight of about 3350. The sticker on the door also gives you the cargo weight. That includes the weight of passengers, hitch, trailer pin, and anything else you might put in the truck. You do the numbers.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
