ford_truck_guy
Feb 16, 2021Nomad
Ronaldlee wrote:
Need advise. We just sold our motorhome and bought this Alpine so we are completely lost on some of its components. My front jacks are leaking down and I am trying to figure out why. Shows no leaks and the tank shows 1/2 full. Should I add fluid or could there be another issue causing this. Thanks for any advise.
DO NOT just add fluid on the basis the tank is low... the trailer MUST be hooked to the trailer( if front jacks are hydraulic ), all slides must be IN and all hydraulic jacks must be raised...
At that point you can check the level, because all the residual fluid will be back in the reservoir.. If you look with the slides out and jacks down it will look low as the lines and cylinders are all full of fluid that was in the reservoir.
About Fifth Wheel Group
