alboy
Feb 18, 2021Explorer
If you have a slide cyclinder leak it should be separate from the legs as each system has a separate solenoid .TWo things,leaking fitting on the hose,it takes very little,or the seals in the leg are bypassing internally.I have a 2014 Landmark ,had same issue.Loctite 5452 thread sealant fixed mine,easy fix.
About Fifth Wheel Group
