cummins2014
May 18, 2021Explorer
Ronaldlee wrote:
Thanks for the information. Upon further review I went underneath and the underbelly is sagging a bit which looks to me as if there is a hydraulic leak at the end of the living room slide which is hydraulic. Do not know if this is something I can fix or not. Do any of you have any advise as to how I should go about this. Thanks again for any input.
You can fix it, its a bit of wrenching is all, unless its the cylinder , but as said in my previous post , those lines are the cheapest hydraulic lines made, and do leak , but its also possible all you have is a loose fitting. The hardest part of the job is dropping that underbelly.
About Fifth Wheel Group
