TheCracker
Jan 21, 2015Explorer
golf_bears wrote:
The first thing I would do, as suggested above, is check the battery voltage at the batteries.
If batteries indicate good voltage then I would remove the monitor panel and check if there is 12v power to the panel.
Don't know why you called Coach-Net, they're an emergency road service company.
Chances are you're panel does not have the 12v power connected. Loose wire a possible problem also.
Coachnet offers technical assistance according to the documentation I have. I will remove the panel and check. Battery voltage is fine, I am hooked to 30A power as well and there is nothing. Please note it is only the tank monitors and battery level portion of the panel not working.
About Fifth Wheel Group
