klassic's avatar
klassic
2016 Jayco
Does anyone have any insider info on the new Eagle Premier, now called North Point for 2016?
I found a list of their standards/option changes.
They also replaced a model.
But that's it.
I hate manufacturers not posting info on their sites about the new model year when they are already taking orders for the new year.
  • ya... that's what I meant
    I had to call a dealer in the US to get some info.
    Looks like the same info you found yellowdog.
    North Point is replacing the Eagle Premier lineup. These enhancements are changes versus the 2015 Eagle Premier
    Décor:
    - 4 New Decors
    - Mahogany – Brownstone furniture
    - Cottonwood – New suede/fabric furniture
    - Hickory – Almond furniture
    - Willow – Havana furniture
    - New carpet color and styling – Still Shaw R2X residential carpeting with padding
    - New herringbone patterned wood plank vinyl flooring
    - New Northridge Carmel wood stain color (slightly lighter)
    - New solid surface kitchen countertop style and color
    - New 3” solid surface backsplash with bead board paneling
    - New hardwood slide out fascias
    - Delete bead board chair rail
    - New interior wallboard (lighter)
    - Contrasting wallboard in living area slide rooms, and other walls needing accent
    - Bourbon Chocolate (dark brown) contrasting window trim
    - Bourbon Chocolate (dark brown) contrasting ceiling cove molding
    - New laminate tops (Sierra stone) in bath lav tops and outside kitchen tops
    - Bath lav faucet to stainless look
    Exterior Changes/Enhancements:
    - New graphics package
    - New front cap styling
    - Front caps fully painted, sanded, and double clear coated (part of Jayco Luxury Fifth Wheels Package)
    - New black metal radius skirting
    - LED exterior lighting (part of Jayco Luxury Fifth Wheels Package)
    - New Magnum Truss XL6 – 6” rafter roof system (part of Jayco Luxury Fifth Wheels Package)
    - Carefree longitude awning with Flex guard fabric armor (part of Luxury Fifth Wheels Package)
    - New Magnum frame system (part of Jayco Luxury Fifth Wheels Package)
    - Same pitches construction wise with drop frame, monster beam, no pre-cracked walls, etc…
    - Deleted sliding LP tray
    - 2-30lb bottles in off doorside compartment
    - Doorside compartment prepped for 3rd – 30lb LP bottle (90lb potential capacity)
    - Battery compartment moved to front storage, new capacity of up to 6 batteries
    2016 Rev. 4/1/2015
    - Backup camera prep (part of Jayco Luxury Fifth Wheels Package)
    - Prewired, and comes with port in bedroom for monitor panel
    - Switch from T60 gelcoat to Medallion high gloss gel coated fiberglass (part of North Point advantage Package)
    - Round roof break points
    - LED utility light on underside of upper deck slideout rooms
    - Solar prep on roof and sidewall (part of Jayco Luxury Fifth Wheels Package)
    - Carmana system compatible with Go Power solar panels
    - Switching to LCI ground control 3.0 system (part of Jayco Luxury Fifth Wheels package)
    - New exterior utility panel
    - Whole coach TV cable
    - Separate satellite TV connections for living area and bedroom
    - Delete microwave, add cooktop in outside kitchens
    - Aluminum hybrid Quad entrance steps (part of Jayco Luxury Fifth Wheels Package)
    - New EZ Cord access panel allowing power cords to be plugged into baggage compartment without having to open door
    Interior Changes/Enhancements:
    - Sofas changing from reclining to trifold and bi-fold hide a beds
    - Franklin American made residential furniture (part of Jayco Luxury Fifth Wheels Package)
    - Stainless steel appliances
    - Recessed oven/range with range cover
    - Linoleum in bath hallway
    - Change to Furrion Bluetooth/HDMI/DVD high output audio/video system (part of Jayco Luxury Fifth Wheels Package)
    - Change to Furrion high output indoor/outdoor speaker system
    - Adding dual USB charging outlets near main living area sofa
    - Indoor/Outdoor central vacuum system with broom kick pan (part of Jayco Luxury Fifth Wheels Package)
    - MCD single blackout roller shades throughout (part of North Point Advantage Package)
    - Stainless steel look refer inserts
    - Eliminate carpeting from kitchen slideouts
    - Add pullout drawers to walk in style pantries
    - Change to 58” TV on 1LJ front living area TV
    - Add built in shelves/cubby storage to bedroom slide fascia (n/a on 1LJ)
    Option Changes:
    - Linoleum in living area moved to standard (where applicable)
    - Added optional Living area carpet(where applicable)
    - Theater seating made standard (1LG, 1LU, 1LX, 1LL)
    - Added optional 2 Recliner Chairs (1LG, 1LU, 1LX, 1LL)
    - Keyless entry made standard (part of Jayco Luxury Fifth Wheels Package)
    - Cargo Accessory receiver made standard (part of Jayco Luxury Fifth Wheels Package)
    - Electric fireplace with wood surround made standard (part of Jayco Luxury Fifth Wheels Package)
    - Trifold and Bi-fold hide a beds now standard
    - Added optional Reclining sofa
    - 12 cu. ft. Norcold 2 way RV fridge now standard
    - Added optional 23 cu. ft. residential refer with water/ice in door and 1000W inverter
    - Added optional Tailgate TV: 39” cargo area TV (not available on outside kitchen models)
    - Added optional Weber Q electric grill with stand
    2016 Rev. 4/1/2015
    - New contents of Customer Value Package (CVP)
    o 15,000BTU Central Air, 20 Gallon Refresh Rate Gas/Electric auto ignition Atwood water heater, Arched interior ceilings, Bath skylight, Bathroom power vent, Bedspread, Floor safe, Folding exterior grab handle, Frameless dark tint windows, LED interior lighting, Security lights, Slam latch gooseneck baggage doors, Sofa and bed pillows, Solid surface kitchen countertops
    - Added mandatory option package (Jayco Luxury Fifth Wheels Package)
    o 6pt. Electric Auto leveling system, Backup Camera Prep, Bluetooth/HDMI/DVD high output entertainment system, Cargo Accessory receiver, Carefree longitude power awning with Flex guard fabric armor, Indoor/Outdoor central vacuum system, Electric fireplace, Franklin American made residential furniture, Keyless main entrance door, LED exterior lighting, Magnum frame system, Magnum Truss XL6 roof system, Mor/Ryde Pin box, Oversized battery compartment, Oversized Aluminum Quad entrance steps, Fully painted, sanded, and double clear coated front cap, Power kitchen vent, Solar Prep, Whisper Quiet “X-dual” ducted A/C system, Whole coach water purification system
    - Added mandatory option package (North Point Advantage Package)
    - Big Screen LED HDTV’s in living areas, Denver 80” Pillowtop mattress in living areas, High hardwood hand rubbed cabinet doors, High gloss premium Ivory colored fiberglass exterior, Mor/Ryde CRE 3000 rubberized suspension system, MCD single blackout roller shades throughout, Linc touchscreen remote control for levelers/slide rooms/Awnings/exterior lights, 32” Bedroom TV w/integrated DVD player
    2016 North Point Model Lineup:
    301RETS (1LG) Carry over replacement for 331RETS
    311RKTS (1LK) Newly improved/revised replacement for 331RKTS
    341RLTS (1LU) Newly improved/revised replacement for 351MKTS
    351RSTS (1LH) Carry over, with improved entertainment center
    361REQS (1LX) Carry over, with flat sofa instead of L-shaped sofa
    375BHFS (1LY) Carry over
    377RLBH (1LL) Brand New floorplan!!!
    383FLFS (1LJ) Newly improved, revised replacement for 371FLFS
    Model Deletion:
    321RLTS (1LF)
    351RLTS (1LM)
  • klassic wrote:
    yellowdog00 wrote:
    Call your dealer. Mine sent me info he had received from Jayco. Option changes, floor plans, interior colors and order sheet. He did not have prices nor weights yet. I ordered a model they continued into 2016. I've seen the 2015 version. Jayco told my dealer they would honor 2015 pricing if I ordered now and weight would be about 100 lbs. greater due to increased structural changes they made to roof. I ordered 2 weeks ago and factory told my dealer it should be delivered end of May. As you probably know, they renamed Premier line to North Point.
    Thanks yellowdog.
    I've been waiting a week for my dealer to get me info..still nothing.
    They are a huge Jayco dealer. I don't know what the problem is.
    They still have about 15 Premier 2015's on the lot. All with $6000-7000 worth of options I don't want.
    Can you verify that they are using Ground Control 3.0 for '16?
    Do you know if their L-shape sofa is still the same in some models?
    Do you have a floor plan of the new 314 RLTS that replaces the 315... Or is it just a new number for the same layout?
    I found this thread on the jayco owners forum. Looks like the LCI is 3.0. I can't find a 314 or 315 Premier model. Do you mean 341 and 351?
    http://www.jaycoowners.com/forums/f6/premier-now-called-north-point-26151.html#post289847
  • Dtank wrote:
    GrumpyandGrandma wrote:
    JAYCO won't post the new models their web-site until dealers get a chance to get some in stock.
    May have changed, but.....
    A bit the opposite.
    "Back in 2006" there were some new floor plans added to the Jayco web site.
    Major So. CA Jayco (and other brands) dealer said there were no such floor plans.
    Told the (very polite) sales person to go have a look.
    (He knew I wanted to *order* one)
    Ans: The internet "person" wasn't there to do that..:R
    Of course, he (the dealer), may have wanted to sell the models he had on his lot. (Thanks - and goodbye)
    Ordered the "stealth" 2006 model elsewhere from a dealer who was well aware of the "new" floor plans and happy to take my order.
    OP - keep checking..;)
    Didn't say you couldn't order or that a dealer had no access to new info/floorplans etc(dealers have their own web-site) just that JAYCO will not update it's public web-site until dealers have a chance to get some stock.
    A bit the opposite.
    Thanks yellowdog.
  • Call your dealer. Mine sent me info he had received from Jayco. Option changes, floor plans, interior colors and order sheet. He did not have prices nor weights yet. I ordered a model they continued into 2016. I've seen the 2015 version. Jayco told my dealer they would honor 2015 pricing if I ordered now and weight would be about 100 lbs. greater due to increased structural changes they made to roof. I ordered 2 weeks ago and factory told my dealer it should be delivered end of May. As you probably know, they renamed Premier line to North Point.
  • Pictures... Floor plans ... Weights... Pricing....someone who has ordered one... Someone who has seen one... Someone besides me that is thinking about one
    You know.... Info.
