thirtydaZe's avatar
Jun 27, 2017
2017 Columbus, bit of suspension Rust/other Corrosion
Was about to jump on a new fw today, got to the dealer late, and couldn't immediately find our salesman. No matter as i wanted to give it a thorough inspection before deciding on it, as we are waffling between 2 different units..
They started locking units on the lot so i was set on going, and while the wife was still inside the camper, i decided to peak under the slides.
Well, it was a bit disappointing, the leaf springs were certainly rust colored, not to the point of any pitting or flaking, but literally rust colored over essentially 100% of them. Also the underside of the front axle was in the same condition.
Upon further inspection, the bolts on the self leveling system are minorly corossive. Its as if it was introduced to a salty road, and not cleaned.
I went and inspected an '18 they had, this was nicely fresh paint, and new looking condition, as well as the bolts on the leveling system.
My question is, given that situation, is this unit something that should be passed on?
Talked to the salesman, of whom ive bought 2 other units in the past, he looked it up, and said that a '17 is something that could very well been sitting on the lot, quite some time as the '18's are out.
My fw sits in a gravel lot most of the time, i would bet it appears to have better looking condition leaf springs than this.
I'm kicking myself for not taking pictures, but we will either purchase this tomorrow or Wednesday pending the input i hope to receive from some of you professionals.
Also, the unit is brand new, and we are in Nebraska, so no salt water. It is however safe to assume, in the winter they treat the hell out of the roads.
  • BarneyS wrote:
    Spray the rusted metal with Rust Kutter from Tractor Supply. Wear breathing protection while doing it if under your rig.
    It will stop the rust and leave a black coating on the metal that will prevent further rusting, or you can paint right over it.
    I used the stuff on my trailer frame years ago and it has never rusted since. I also painted over it with black Rustoleum paint. There are other brands also but I don't know the names of them.
    Barney
    Thanks for the Link.
  • Spray the rusted metal with Rust Kutter from Tractor Supply. Wear breathing protection while doing it if under your rig.
    Barney
  • Mine was built in Dec of 15, and I have no rust underneath. Maybe Dealer ACTUALLY DID clean underneath when they received the unit??
    Jim
  • When was the mfr date of the Columbus? Like AP said, more than likely it was made during the winter or early spring and shipped/ran on roads w/ salt on them. It may look horrible, but doubt very much the structural integrity is compromised. Being a '17 they want it off their lot in worst way. So see about a further reduction in price as pointed out by AP for both the "age" and rust. Can't hurt.
  • Nothing is going to fall apart. The brand new shiny one will look like that after a year. They don't put any primer on most of the parts just some cheap black paint. You can touch it up with a spray can of Rustoleum ever couple years if you like. It certainly wouldn't stop me from buying it. If you really want to see rust look under a trailer that's a few years old..
    B.O.
  • It was probably exposed to road salt in Indiana. I was told that these units that were built in the winter and pulled over the salt treated roads are supposed to be neutralized when they get to their destination.
    I have a 2015 that has the same problem. I have neutralized all of the rust on the frames and the bolts and repainted them. I have not done anything to the springs yet.
    I don't think the rust is anything serious but it does look bad and it will spread if it is not addressed.
    If you don't mind a little manual labor maybe you can get a deep enough discount to make it worth your while.
    There are rust neutralizers that you mix with water and spray on the rust and it does a good job of stopping the rust but you also need to paint it.
    Good luck on your decision.
