chineselady00
Oct 25, 2018Explorer
obgraham wrote:
OP, I think you should change your approach to RV planning. Don't look at the cities and urban areas as a goal for any of your driving, but rather as an obstruction. With an RV you want to be out in the countryside, looking for scenic views, nice roads, and offbeat things to see.
An RV is not designed to visit Toronto, Detroit, Chicago, Denver, and Los Angeles, although you might have to pass through them to get where you are going.
And don't obsess about the mountains. I won't comment on whether your truck is the right one or not, but most all RV's will handle the normal grades across the US and Canada, even if you have to slow down and use up fuel like it was free.
We've done both countries side to side and top to bottom, and never gotten stuck on a mountain grade. (Well, there were one or two where I had to pull over and cool her down a bit!)
Thanks a lot. Yes, not going inside the big cities. Thanks for encouraging us! Any must visit in your mind after you have done both countries?
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
