- pcm1959Explorer II
Retired JSO wrote:
We were experiencing a sewer smell as we exited the shower. I opened the cabinet below the lavatory and was almost consumed with the smell. I removed the air admittance valve and found one at Home Depot cost about $6.99. It didn’t stop the smell. Located another at Home Depot, Oatly brand about $12. It worked and stopped our problem. Don’t waste your money on the cheap one.
I replaced all of ours with the $7 Oatey model when our rig was new. The ones that come in RVs are typically the cheapest available. I think one of them may have become faulty after 6 years now. So I'm researching what will be a better replacement. Studor generally has a good reputation but I have read better reviews about the Oatey models. - Retired_JSOExplorer IIWe were experiencing a sewer smell as we exited the shower. I opened the cabinet below the lavatory and was almost consumed with the smell. I removed the air admittance valve and found one at Home Depot cost about $6.99. It didn’t stop the smell. Located another at Home Depot, Oatly brand about $12. It worked and stopped our problem. Don’t waste your money on the cheap one.
- Fsch5748ExplorerThanks for the reply. I have 2 grey tanks and 2 black tanks.
The smell comes from kitchen area only. The 1/2 bath off kitchen is rarely used! Wife insisted on it, funny it’s main use is storage! The smell definitely comes from kitchen grey tank. - pcm1959Explorer II
Fsch5748 wrote:
Located roof vents no visible blockage and minimal odor!
I’m inclined to think vent pipe extends into holding tank to far!
Odor gets stronger as tank fills!
I totally agree on this one. The pipe is installed to deep into the tank OR has slipped down. Do you notice this with the black OR grey tank. Mine uses one vent stack joined by a tee so only one vent on the roof. One way you can determine if you have a venting problem is to get on the roof, place a single ply tissue over around the vent (or stick your nose around the vent to smell for odor) and then have someone flush the toilet as well as pulling the drain plug on a partially filled sink. A properly vented tank will expel air from the vent pipe on the roof.
I was having this problem on my rig and I fixed it myself. The key is being able to get to the top of the tank which I was able to do fairly easily. - Is the yes to the hot water?
If so, open your hot water tank and flush real good... just let the water run through the tank for a bit, that should clear up the smell..
You can also sanitize the system after
Sometimes I get a stagnant water smell if I keep my hot water tank filled between trips.... - Fsch5748ExplorerYes
- pcm1959Explorer IIHere's an excellent explanation of the holding tank vent system.
https://www.youtube.com/watch?v=E731e8asMyI - do you smell it more when the HOT water is running?
- Fsch5748ExplorerLocated roof vents no visible blockage and minimal odor!
Odor gets stronger as tank fills! - pcm1959Explorer II
Fsch5748 wrote:
All good info! Have been unable to locate vent! Nothing visible under any sinks! Chased pipes into cargo area. One pipe turn up and I think is vent! Nothing visible from roof! Removed cap and odor was slight! Washer dryer is in front of trailer! Odor comes distinctly from kitchen area! Will continue to chase down problem! All replies are welcomed! Together we will solve this
Thanks
Are you saying there is not tank vent on the roof? The majority of manufacturers provide a vent stack for each tank. You should have at least one vent stack on the roof. Lets determine that.
About Fifth Wheel Group
