teegee1025
Jun 07, 2020Explorer
JTrac wrote:
We picked up our Pinnacle 32RLTS Friday. A very thorough 3 hour walk PDI and that system was explained. I just wish I had paid closer attention. My problem is I'm not sure about the system as a whole. It is something extra to mess with but I do like the idea of have fresh drinking water and ice available. We generally don't drink water straight from the tap and have used a Britta for a number of years while traveling. My concern is once you have used the 5 gallons unless you have access to a refill it's back to the Britta.
I found a couple of Jayco owners forums that you may want to consider joining. You may be more likely to get Jayco specific info.
Congratulations on your new 32RTLS! We are fortunate enough to have a reverse osmosis system at the house so we can fill it at home. It should be okay for our weekend trips. Once retirement and longer trips come, we will probably use a Brita after the 5 gallons runs out.
Not sure if you saw my post but I found the pump and switch late last night while putting things away. On the floor of the island...UNDER THE BOTTOM DRAWER!!! Who designed this?? Our 5 gallon bottle was not attached at this point but I did turn on the motor. Seems very loud but maybe because no water running thru it!!
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
