Robert6401ExplorerDec 05, 2016235 85 16 tires, what are you guys running?Really not seeing many options other than the Towmax ST tires that came on the rig. Talking dual 7k axles on a 5er TH with gvwr of 15.5k.
fj12ryderExplorer IIIDec 05, 2016Sailun S637 235/85-16 G-rated tires, running about 90-95 psi. A triple axle toyhauler with 12,000 lbs. on the axles.
Related ContentRun Flat Tires ?Bias ply vs. radial tiresTires- Tires - TiresWould you run these tires?Running wrong tire psi
