N-Trouble
Dec 06, 2016Explorer
fj12ryder wrote:N-Trouble wrote:I hope you're not suggesting that one should ignore the weight rating. If you need 3200 lbs. of carrying capacity then you shouldn't be looking at an E-rated 16" LT tire. It's just that simple.
I wouldnt get two hung up on LT tire capacity rating vs ST. They are rated based on different standards and speed ratings. "Technically" the Duravis R250s I put on my trailer are lower weight rating than the ST tires that came off the trailer BUT one look/feel comparing the tires and sidewall construction side-by-side it becomes very obvious which tire I would put my faith in. No comparison... LT for the win!
Im referring to LT vs ST weight ratings. They are not based on comparable standards.
About Fifth Wheel Group
