goducks10
Dec 06, 2017Explorer
Whats the dry pin weight on the Solitude. Most are in the 2500+ lb range. You'll be at 3000= lbs on the rear axle. Thats the max for your RAWR right now. You'll need to upgrade the tires and if needed the rims too.
JMO but depending on which Solitude you're looking at, some are too much 5er for that 2500.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
