caysea7254
Jun 12, 2014Explorer
2WD or 4WD
ok my husband and I are getting ready to buy a 2014 Silverado 3500 HD. he thinks he needs a 4WD and I think we should stick with 2WD. it looks a little lower to ground not so high to step up and will ...
bobx2 wrote:blw2 wrote:
I have many times gone places in a 2wd truck with limited slip, that friends in 4wd trucks could not go.
Hahahahahaha, oh that's priceless. I would like to hear your friends versions of these stories. :B
To the OP, just having the option to use it if you think you might need it makes it worthwhile to have. As a couple others have mentioned, having low range can come in handy when maneuvering into steep sites or driveways. I have used low range on a hard, dry surface while backing into a rather steep site. You can basically idle up and into position, as opposed to high revving with one foot covering the brake just in case it takes off. Much easier on the transmission as well, with less slippage of the clutches.
