laknox
Apr 07, 2015Nomad
30 amp / 50 amp
We're considering a new FW and a couple of the options are upgrading the single AC to 15k with 2nd AC prep (I believe the prep is standard). There is also a 30 to 50 amp option. First question; if I...
laknox wrote:
We're considering a new FW and a couple of the options are upgrading the single AC to 15k with 2nd AC prep (I believe the prep is standard). There is also a 30 to 50 amp option. First question; if I upgrade to the 15k AC will I =need= 50 amp or is that just "belt and suspenders" for a single AC. Second question; if I have the 15k AC and get the 50 amp service, can I use a 30 amp cord until such time as I add a 2nd AC and would be required to use the heavier cord? Third question; would I simply just be better off using 50 amp from the get-go, even with only 1 AC?
Lyle
